tomtm Posted August 5, 2021 Share Posted August 5, 2021 Hi, I try to pin a trolley (RBD) to the hand of an animated alembic character mesh, it should pull this object. The pinRBD constraint just works with static mesh, I can't find out how to pin it to the surface of the animated mesh. Any help would be very appriciated. Greets Tom Quote Link to comment Share on other sites More sharing options...
tamagochy Posted August 5, 2021 Share Posted August 5, 2021 Glue constraint works with animated objects, all other not Quote Link to comment Share on other sites More sharing options...
Ultraman Posted August 5, 2021 Share Posted August 5, 2021 (edited) 2 hours ago, tomtm said: Hi, I try to pin a trolley (RBD) to the hand of an animated alembic character mesh, it should pull this object. The pinRBD constraint just works with static mesh, I can't find out how to pin it to the surface of the animated mesh. Any help would be very appriciated. Greets Tom u can check the rbd hip file , I think u can find in the soft body part ur question .. Edited August 5, 2021 by Ultraman Quote Link to comment Share on other sites More sharing options...
Ultraman Posted August 5, 2021 Share Posted August 5, 2021 and this one Quote Link to comment Share on other sites More sharing options...
tomtm Posted August 6, 2021 Author Share Posted August 6, 2021 Hi, thanks a lot for all the hints. I tried it with Glue Adjacent pieses. It works somehow but I can't believe this is the solution :-) I thought it should be easy for Houdini, or maybe I have a complete blackout. I added the Scene, the Character Alembic and the .hip Any modifications would be welcome. Greets Tom Character_Walk.zip Quote Link to comment Share on other sites More sharing options...
Ultraman Posted August 6, 2021 Share Posted August 6, 2021 18 hours ago, tomtm said: Hi, thanks a lot for all the hints. I tried it with Glue Adjacent pieses. It works somehow but I can't believe this is the solution :-) I thought it should be easy for Houdini, or maybe I have a complete blackout. I added the Scene, the Character Alembic and the .hip Any modifications would be welcome. Greets Tom Character_Walk.zip check hip RBD_Pin_Soft.hiplc Quote Link to comment Share on other sites More sharing options...
tomtm Posted August 6, 2021 Author Share Posted August 6, 2021 2 hours ago, Ultraman said: check hip RBD_Pin_Soft.hiplc wow, this solution looks great in results! Thanks a lot. But Houdini is so complicated with this case. Sidefx should have something like in vellum with simple pin to "another" geometry method. I never would have found out by myself. But this is a great setup for this. It could be used for truck trailers and my other setups. Thanks & Greets Tom Quote Link to comment Share on other sites More sharing options...
