archz2 Posted August 26, 2021 Share Posted August 26, 2021 I am using version 2.6.41 of redshift. How can I add multiple camera angles in Redshift and batch render them all at once? Quote Link to comment Share on other sites More sharing options...
stavrogin Posted October 14, 2021 Share Posted October 14, 2021 You can make multiple RS Rops and assign them to different cameras. Then wire them into a merge, and under options set it to node by node then hit render. 1 Quote Link to comment Share on other sites More sharing options...
archz2 Posted October 18, 2021 Author Share Posted October 18, 2021 Okay I can understand making multiple RS Rops and assign them to different cameras and wiring them into a merge. Can you please share a screenshot for setting it to node by node? Quote Link to comment Share on other sites More sharing options...
Sepu Posted October 18, 2021 Share Posted October 18, 2021 Like this, if you do node by node you do not need that, if you want to render all of them at the same time uncheck "non_blocking....." Quote Link to comment Share on other sites More sharing options...
stavrogin Posted October 18, 2021 Share Posted October 18, 2021 (edited) click on controls, and it's under Dependency Rendering Settings Edited October 18, 2021 by stavrogin Quote Link to comment Share on other sites More sharing options...
