Orient away from object
jonidunno
Hello,
I'm trying to wrap my head around this... how could I have the orient of nearby points (possibly with a falloff) point avoid (point away from) a nearby object?
My setup right now consists of copied points on a surface and would love them to directional rotate away from the sphere as it gets close to them... here is a scene file if anyone wants to take a stab!
pointAway01.hiplcFetching info...
newton's law and try to use this it works
function float Kernel(vector r ; float h){
    float q = length(r);
    q /= h;
    float factor =  1.0f / (PI  * h * h * h );
    if( q>0 && q<=1){
        float right =  1.0f - 1.5f  * (q * q) * (1.0f - q/ 2.0f) ;
        return factor * right;
    if(q >1 && q <=2 )
        float left = factor / 4.0f;
        float right = pow(2.0f - q , 3);
        return left*right;
    if(q>2)
        return 0;
    return 0;
function vector GradKernel(vector r; float h){
    q /= h;
    vector dir = normalize(r);
    vector retgrad = set(0,0,0);
    if( q<=1){
        retgrad = dir * (factor / h) * (-3.0 * q + 2.25f * q*q);
    if( q<2){
        retgrad = dir * (-0.75f * (factor / h) * pow((2.0f - q),2) );
    return retgrad;
float h = chf("h");
@P.y = Kernel(@P, h);
@N = GradKernel(@P, h);
NewtonsLaw.hiplcFetching info...
Edited by Librarian
  • Thanks 2
    q /= h;
    if( q>0 && q<=1){
    if(q >1 && q <=2 )
        return left*right;
    if(q>2)
        return 0;
    return 0;
    q /= h;
    if( q<=1){
    if( q<2){
    return retgrad;
float h = chf("h");
Expand
Thanks! I will take a look appreciate you taking to the time to look.
Hi jon,
this is how you could map distance and direction towards a surface into an orient attribute:
float dist_min = chf('min_distance');
float dist_max = chf('max_distance');
float angle_max = chf('max_angle');
vector pos = minpos(1, v@P);
float dist = distance(pos, v@P);
vector dir = normalize(pos - v@P);
float mask = 1.0 - smooth(dist_min, dist_max, dist);
float angle = radians(angle_max) * mask;
vector axis = normalize(cross(dir, v@N));
p@orient = quaternion(angle, axis);
orient_away.hiplc
  • Thanks 1
  • 2 weeks later...
  On 9/10/2021 at 8:38 AM, konstantin magnus said:
Hi jon,
orient_away.hiplcFetching info...
Expand
Hey Konstantin,
Appreciate it!
