jonidunno Posted September 9, 2021 Share Posted September 9, 2021 Hello, I'm trying to wrap my head around this... how could I have the orient of nearby points (possibly with a falloff) point avoid (point away from) a nearby object? My setup right now consists of copied points on a surface and would love them to directional rotate away from the sphere as it gets close to them... here is a scene file if anyone wants to take a stab! pointAway01.hiplc Quote Link to comment Share on other sites More sharing options...
Librarian Posted September 9, 2021 Share Posted September 9, 2021 (edited) newton's law and try to use this it works function float Kernel(vector r ; float h){ float q = length(r); q /= h; float factor = 1.0f / (PI * h * h * h ); if( q>0 && q<=1){ float right = 1.0f - 1.5f * (q * q) * (1.0f - q/ 2.0f) ; return factor * right; } if(q >1 && q <=2 ) { float left = factor / 4.0f; float right = pow(2.0f - q , 3); return left*right; } if(q>2) { return 0; } return 0; } function vector GradKernel(vector r; float h){ float q = length(r); q /= h; vector dir = normalize(r); float factor = 1.0f / (PI * h * h * h ); vector retgrad = set(0,0,0); if( q<=1){ retgrad = dir * (factor / h) * (-3.0 * q + 2.25f * q*q); } if( q<2){ retgrad = dir * (-0.75f * (factor / h) * pow((2.0f - q),2) ); } return retgrad; } float h = chf("h"); @P.y = Kernel(@P, h); @N = GradKernel(@P, h); NewtonsLaw.hiplc Edited September 9, 2021 by Librarian 1 2 Quote Link to comment Share on other sites More sharing options...
jonidunno Posted September 9, 2021 Author Share Posted September 9, 2021 1 hour ago, Librarian said: newton's law and try to use this it works function float Kernel(vector r ; float h){ float q = length(r); q /= h; float factor = 1.0f / (PI * h * h * h ); if( q>0 && q<=1){ float right = 1.0f - 1.5f * (q * q) * (1.0f - q/ 2.0f) ; return factor * right; } if(q >1 && q <=2 ) { float left = factor / 4.0f; float right = pow(2.0f - q , 3); return left*right; } if(q>2) { return 0; } return 0; } function vector GradKernel(vector r; float h){ float q = length(r); q /= h; vector dir = normalize(r); float factor = 1.0f / (PI * h * h * h ); vector retgrad = set(0,0,0); if( q<=1){ retgrad = dir * (factor / h) * (-3.0 * q + 2.25f * q*q); } if( q<2){ retgrad = dir * (-0.75f * (factor / h) * pow((2.0f - q),2) ); } return retgrad; } float h = chf("h"); @P.y = Kernel(@P, h); @N = GradKernel(@P, h); NewtonsLaw.hiplc Thanks! I will take a look appreciate you taking to the time to look. Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted September 10, 2021 Share Posted September 10, 2021 Hi jon, this is how you could map distance and direction towards a surface into an orient attribute: float dist_min = chf('min_distance'); float dist_max = chf('max_distance'); float angle_max = chf('max_angle'); vector pos = minpos(1, v@P); float dist = distance(pos, v@P); vector dir = normalize(pos - v@P); float mask = 1.0 - smooth(dist_min, dist_max, dist); float angle = radians(angle_max) * mask; vector axis = normalize(cross(dir, v@N)); p@orient = quaternion(angle, axis); orient_away.hiplc 1 Quote Link to comment Share on other sites More sharing options...
jonidunno Posted September 22, 2021 Author Share Posted September 22, 2021 On 9/10/2021 at 1:38 AM, konstantin magnus said: Hi jon, this is how you could map distance and direction towards a surface into an orient attribute: float dist_min = chf('min_distance'); float dist_max = chf('max_distance'); float angle_max = chf('max_angle'); vector pos = minpos(1, v@P); float dist = distance(pos, v@P); vector dir = normalize(pos - v@P); float mask = 1.0 - smooth(dist_min, dist_max, dist); float angle = radians(angle_max) * mask; vector axis = normalize(cross(dir, v@N)); p@orient = quaternion(angle, axis); orient_away.hiplc Hey Konstantin, Appreciate it! Quote Link to comment Share on other sites More sharing options...
