Vop mix between many inputs
Hello
So we all know the mix node in a point vop. If you feed in two sets of point positions. Then adjust the mix. You basically created a blend shape between the to positions.
Well. What if you have several position. So I have a animation. I save the position of the last 5 frames. How would I setup a mix to run across those 5 positions. For example
0% = current frame
20%=frame -1
40% =frame -2
and so on......
So I can paint an attribute and have different parts of the animation lag behind by different amounts.
Cheers
3 hours ago, revelationsr said:
In the simplest terms. I have a polygon. 4 points.
Point 1 = current frame
point 2 = frame -1
point 3 = frame -2
point 4 - frame - 4
So. I use a timeshifts to create attributes that stores the point position for frames -4 to current.
what about  "spline "  Function doesn't help?
https://www.sidefx.com/docs/houdini/vex/functions/spline.html
