Python module - create/delete nodes inside locked asset
papsphilip
how can i delete/create nodes in a locked hda from the python module?
i am using a button with a callback script that runs a delete() function
for n in node.children(): n.destroy(True)
i get an error message that i don't have permissions because the asset is locked. Is there a way around this?
callback_parm_kwargs_hda_node.hip
what do you mean predefine it as editable? in the node tab there is the "Editable Nodes" field, but that concerns a specific nodes inside the hda.
i wanted a locked asset i can pass around to other creators where they would press a button and create a bunch of nodes, press another and delete them. without having access to the network inside.
