Fetch Value At Specific Time in VEX
jamesearnest244
If you connect the TimeShift to the second input of the attributeWrangle node, you can fetch from it using the point function.
vector time_shifted_attrib = point(1,"my_attrib",@ptnum);
Note: Using python, you can evaluate a parameter channel at a certain point in time, but that's not the same as an attribute.
https://www.sidefx.com/docs/houdini/hom/hou/Parm.html
Edited by Atom
