How do I fix jittering RBD material fracture chunks?
Neikke
3 hours ago, Ultraman said:
Hi.
Try to Deactivate some areas that don't need to be Sim.
and as I can see did u use Next Constraint and last active Contrasint is Hard or Soft, u must back ur constraint to Glue with -1 Value to Freeze your RBD Sim.
Yeah I have next constraint as Soft, but don't know what you mean regarding "last active Contrasint is Hard or Soft". Can you pls attach a screen?
Also can you maybe attach a screen where should I freeze my constraint to Glue with -1? Thanks a lot!
Edited by Neikke
11 hours ago, Neikke said:
Attaching screens of my setup. No matter what I do I get jittery chunks on my simulation. Any way I can get this bug fixed? Thanks in advance!
without hip file is hard to judge - and for freezing, u can drop sop solver inside the DOP Network Constraint and check Angle Soft Constraint value if was bigger some Value change ur Constraint to Glue -1
  • 2 weeks later...
You could as well damp the velocity over time inside the solver, something like
if(@Frame>50) v@v*=0.9;
The more you want to damp it, the smaller the value
Also, it would be interesting to increase your substep and see if it changes something, maybe your solver does not have enough to be able to figure out which parts should stop moving ?
Thanks a lot mate, I will give it a try!
