Indie supplementary license
Xtro
Is it possible to render on one pc that has the 'supplementary' (not another, second indie license) license installed, while continuing to work on another shot (sim) on my main pc with the indie license ? That way i don’t lose time to wait to render and only to continue when its finished. Because as far as i understood the terms, with one Indie license there comes the supplementary license for use on second pc, but it states that  only one indie can be run at the time - so is the solution for this to render using a command line tool?
Also, does this work with 3rd party render engines?
Yes, for that purpose you'd need to use either the 'hbatch' or 'hython' command-line utilities, as those will consume an Engine license which are free with Indie. And yes, that works with 3rd party render engines, as you are still running Houdini, just without a GUI.
