Add to group and track age
14 hours ago, papsphilip said:
i have an initial selection of primitives that i append to over time. How can i track the birth and age of the newly added primitives in the group?
i m stuck in the birth-age problem, but i have managed to isolate the newly added prims to the existing group.
look at the attached file
add_to_group_and_track_age_01.hipnc
it works like a charm thank you!! The birth attribute is not quite right for some reason. i was expecting an integer for each prim that doesn't change over time
Also how can i extrude or transform those newly created pieces, while deleting their previous non deformed/transformed state?
is it doable in the same solver?because i ve been at it for some hours with no luck although it seems straightforward
(sorry the second file is my hacky way)
add_to_group_and_track_age.hip
Edited by papsphilip
It does not change and you can easily transform float type to integer
it is not necessary to use solver sop for this
add_to_group_and_track_age_02.hipnc
