Copy geo to connecting edges of a mesh.
jlrvfx
I would like to copy two sets of primitives to a grid. One set of primitives I want to copy to each point on a grid. The second set I would like to copy to the edges that join the points together. Ideally, these connections would scale with the length of the connections.
Carving the grid will result in two copies of the tube in the interior where there were originally two shared edges:
ShareX_vzEpmZQ0mY.png.46382f730c252d4736e1900886bb5ab2.pnghoudini_KWbXOyOvI7.thumb.png.2d14275ab47b10953e7b28e28d1838ea.png
If I clean the result of the carve to remove the duplicates it causes issues with the orientation. Assuming it is averaging the normals:
houdini_5XZJwOdig6.png.345158db5a8f0c393945f0e2da4635e9.pnghoudini_JFtMqw1OcY.png.5fb6852bf35b962748125e4ab527d9ad.png
The result I am looking for is like this:
I feel like there must be a simple way to do this that I am overlooking.
gridCopy.hiplc
Edited by jlrvfx
Thanks, both. I have used a pipe in the above example to simplify things, but in the end, I would like it to take geo metry modeled elsewhere and be able to place that between the connections so hoping to avoid sweeping. So trying to achieve something like this with the red geo copied to the points and the green bridging the connections. I think zeynes version with the foreach loop might be the key to this so looking into making that work now.
Hi James,
you can copy and scale meshes on converted lines by adding points to their center.
float radius = chf('radius');
int pt_prim = primpoint(0, i@primnum, 0);
vector pos_pt = point(0, 'P', pt_prim);
vector nml_pt = point(0, 'N', pt_prim);
vector dir = normalize(pos_pt - v@P);
float scale = f@restlength - radius;
int pt_add = addpoint(0, v@P);
setpointattrib(0, 'up', pt_add, nml_pt, 'set');
setpointattrib(0, 'N', pt_add, dir, 'set');
setpointattrib(0, 'pscale', pt_add, scale, 'set');
removeprim(0, i@primnum, 1);
copy_to_lines.hiplc
  • Like 2
  • Thanks 1
  • 2 weeks later...
On 12/18/2021 at 6:03 PM, konstantin magnus said:
Hi James,
copy_to_lines.hiplc
This is so cool! Is there a way to use this method to make the object (the lobster) connecting around a mesh like the bodies around the bust in this example @konstantin magnus ?
  • 4 months later...
