Polysplit by another mesh? (a.k.a. Clip SOP with arbitrary mesh)
raincole
How could I split a mesh with another mesh/surface? Like Boolean SOP's shatter mode, but instead of cut A by B into separate parts, I'd like to create new edges and points on A by the seam between A and B.
Clip SOP's "Keep All Primitives" mode does that. But Clip can only split by a plane. It doesn't have a second input. Is it possible to split by a mesh?
Edited by raincole
7 hours ago, eikonoklastes said:
Dropping a Fuse after the Boolean Shatter will replicate that effect.
Edit: Ignore that. Use a Clean SOP instead, after the Shatter, and set it to Consolidate Points and Fix Overlaps.
Clean SOP does the trick, thank you!
