hmihalis1 Posted March 30, 2022 Share Posted March 30, 2022 Hi all, I'm working with a character .fbx imported from another package, and need to extract the painted weights for a specific bone to a point attribute to use as a mask. Right now i'm using the labs Name from Capture Weight node, which unpacks the weights and saves the name of the bone that has the highest influence on a point to string attribute by just returning the first entry. Then I use the following vex to do a search for a particular bone(s) in that string attribute, something like "eyelidLower*": string term = chs("search_for"); int found = match(term, s@bone); @mask = found; that returns 1 for all the points that match the term so i can a linear mask, but I want to return and sum the actual weights - is this possible? Many thanks Quote Link to comment Share on other sites More sharing options...
Librarian Posted March 30, 2022 Share Posted March 30, 2022 //reduce int maxInf = (int)chf("maxInfluence"); f[]@boneCapture_data; i[]@boneCapture_index; int length = len( @boneCapture_data ) - maxInf; if(length > 0){ for(int i = 0; i < length; i++) { removeindex( @boneCapture_data, argsort(@boneCapture_data)[0] ); removeindex( @boneCapture_index, argsort(@boneCapture_data)[0] ); } } //norml f[]@boneCapture_data; float scaleFactor = 1.0 / sum(@boneCapture_data); for(int i = 0; i < len(@boneCapture_data); i++) { @boneCapture_data[i] = @boneCapture_data[i] * scaleFactor; } //round float accuracy = 1.0 / chf("accuracy"); f[]@boneCapture_data; for(int i = 0; i < len(@boneCapture_data); i++) { @boneCapture_data[i] = rint (@boneCapture_data[i] * accuracy ) / accuracy; } int maxIdx = reverse( argsort(@boneCapture_data) )[0]; @boneCapture_data[maxIdx] = @boneCapture_data[maxIdx] + ( 1.0 - sum(@boneCapture_data) ); //addsource string sourceBone = ch("sourceBone"); string targetBone = ch("targetBone"); // check bone name exist int sourceIndex = -1; int targetIndex = -1; string nameList[] = detail(0, "boneCapture_pCaptPath"); for(int i = 0; i < len(nameList); i++) { if(nameList[i] == sourceBone){ sourceIndex = i; } if(nameList[i] == targetBone){ targetIndex = i; } if(sourceIndex != -1 && targetIndex != -1){ break; } } if( sourceIndex == -1 || targetIndex == -1){ // do nothing when bone name is invailed return; } else{ f[]@boneCapture_data; i[]@boneCapture_index; int source = -1; int target = -1; for(int i = 0; i < len(@boneCapture_index); i++) { if(@boneCapture_index[i] == sourceIndex){ source = i; } if(@boneCapture_index[i] == targetIndex){ target = i; } if(source != -1 && target != -1){ break; } } // update weight value; if(source != -1 && target == -1){ @boneCapture_index[source] = targetIndex; } if(source != -1 && target != -1){ @boneCapture_data[target] = @boneCapture_data[target] + @boneCapture_data[source]; removeindex( @boneCapture_data, source ); removeindex( @boneCapture_index, source ); } } //dell anused string boneNames[] = detail(0, "boneCapture_pCaptPath"); float boneXforms[] = detail(0, "boneCapture_pCaptData"); string captNames[] = detail(0, "capt_names"); float captXforms[] = detail(0, "capt_xforms"); int captParents[] = detail(0, "capt_parents"); string boneNamesKeep[] = {"root", "thumb_03_r"}; // check unused bone name list int boneNames_Used[]; for(int i = 0; i < @numpt; i++){ int ptBone[] = point(0, "boneCapture_index", i); for(int j = 0; j < len(ptBone); j++){ boneNames_Used[ ptBone[j] ] = 1; } } for(int i = 0; i < len(boneNamesKeep); i++){ for(int j = 0; j < len(boneNames); j++){ if(boneNamesKeep[i] == boneNames[j]){ boneNames_Used[ j ] = 1; } } } // remove unused bone name list int originalIdx[]; int oIdxCount = 0; for(int i = (len(boneNames) - 1) ; i >= 0; i--){ if(boneNames_Used[i] == 0){ removeindex(boneNames, i); } else{ originalIdx[oIdxCount] = i; oIdxCount++; } } originalIdx = reverse(originalIdx); // update bone Xform, parent list float newBoneXforms[]; float newCaptXforms[]; int newCaptParents[]; for(int i = 0; i < len(originalIdx); i++){ int bIdx = originalIdx[i] * 20; int cIdx = originalIdx[i] * 16; append(newBoneXforms, boneXforms[bIdx:bIdx+20]); append(newCaptXforms, captXforms[cIdx:cIdx+16]); newCaptParents[i] = captParents[ originalIdx[i] ]; } // update parent index for(int i = 0; i < len(newCaptParents); i++){ int check = 0; for(int j = 0; j < len(originalIdx); j++){ if(newCaptParents[i] == originalIdx[j]){ newCaptParents[i] = j; check = 1; break; } } if(check == 0){ newCaptParents[i] = -1; } } // update bone index of point for(int i = 0; i < @numpt; i++){ int ptBone[] = point(0, "boneCapture_index", i); for(int j = 0; j < len(ptBone); j++){ for(int k = 0; k < len(originalIdx); k++){ if(ptBone[j] == originalIdx[k]){ ptBone[j] =k; break; } } } setpointattrib(0, "boneCapture_index", i, ptBone); } // update attriute s[]@boneCapture_pCaptPath = boneNames; f[]@boneCapture_pCaptData = newBoneXforms; s[]@capt_names = boneNames; f[]@capt_xforms = newCaptXforms; i[]@capt_parents = newCaptParents; //swap source string sourceBone = ch("sourceBone"); string targetBone = ch("targetBone"); // check bone name exist int sourceIndex = -1; int targetIndex = -1; string nameList[] = detail(0, "boneCapture_pCaptPath"); for(int i = 0; i < len(nameList); i++) { if(nameList[i] == sourceBone){ sourceIndex = i; } if(nameList[i] == targetBone){ targetIndex = i; } if(sourceIndex != -1 && targetIndex != -1){ break; } } if( sourceIndex == -1 || targetIndex == -1){ // do nothing when bone name is invailed return; } else{ f[]@boneCapture_data; i[]@boneCapture_index; int source = -1; int target = -1; for(int i = 0; i < len(@boneCapture_index); i++) { if(@boneCapture_index[i] == sourceIndex){ source = i; } if(@boneCapture_index[i] == targetIndex){ target = i; } if(source != -1 && target != -1){ break; } } // update weight value; if(source != -1 && target == -1){ @boneCapture_index[source] = targetIndex; } if(source == -1 && target != -1){ @boneCapture_index[target] = sourceIndex; } if(source != -1 && target != -1){ float targetWeight = @boneCapture_data[target]; @boneCapture_data[target] = @boneCapture_data[source]; @boneCapture_data[source] = targetWeight; } } @hmihalis1 Quote Link to comment Share on other sites More sharing options...
Keshaw singh Posted May 23, 2022 Share Posted May 23, 2022 big thanks Quote Link to comment Share on other sites More sharing options...
