Making an expression to auto-version up caches to match the hip file version
Hyrulean
Hello everyone.
I have looked this up a lot online but I can't find a way to solve it.
I am looking for a way to get the last 4 digits of a file so I can make my caches auto version up, acording to my hipfile name.
So basically if I have a hip file called "shotname_fx_v001.hip", then the last 4 digits I would call it in and make that be my version. I would also need to do a toggle to make that only be active when I need it.
Any ideas on how I could approach that?
  • 3 weeks later...
A suggestion, don't use hard-coded numbers, eventually will break... perhaps something like;
file_name = hou.hipFile.basename()
return file_name.split("_")[-1]
In this way, as long as you keep using the same template separated by underscores, it will work, independently of the length of the string or even the amount of underscores.
  • 1 month later...
For anyone working with versioning or extracting and data from filepaths I would recommend looking into regular expressions.
import re
match = re.search('v(\d+)')
return match.group(1)
This looks for any string matching a "v" followed by numbers and returns the numbers.
eg. "shotname_fx_v001.hip" -> "001"
It's is very powerful once you get the hang of it and essential for pipelining tasks.
Edited by PixelNinja
And one I use all the time.
def returnValidHoudiniNodeName(passedItem):
    # Thanks to Graham on OdForce for this function!
    # Replace any illegal characters for node names here.
    return re.sub("[^0-9a-zA-Z\.]+", "_", passedItem)
