wyy Posted April 11, 2022 Share Posted April 11, 2022 Is it possible to get color and alpha values using attribute from map? Now it loads only Cd.r, Cd.g, Cd.b values. Quote Link to comment Share on other sites More sharing options...
fencer Posted April 12, 2022 Share Posted April 12, 2022 (edited) Try with copnet. AlphaToAttr_v01.hip Edited April 12, 2022 by fencer 1 1 Quote Link to comment Share on other sites More sharing options...
dleonhardt Posted April 12, 2022 Share Posted April 12, 2022 Or you could open up the Attribute from Map and export the Alpha from the Attribute VOP inside. Because the Texture VOP inside is set to read RGBA, the Alpha channel just doesn't get exported for some reason. dl_attrib_from_map_alpha.hipnc Quote Link to comment Share on other sites More sharing options...
