bentraje Posted April 15, 2022 Share Posted April 15, 2022 (edited) Hi, Carving letter from an object seems fairly straight forward (i.e. use boolean). But carving with an equal extrusion gives me problems. Please see illustration below: Is there a way around this? carve_letter_equal_extrusion.hipnc Edited April 16, 2022 by bentraje Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 15, 2022 Share Posted April 15, 2022 try WRAP SVG Sop from "baku89" on Github 2 Quote Link to comment Share on other sites More sharing options...
Atom Posted April 15, 2022 Share Posted April 15, 2022 (edited) My first instinct would be to project the 2D font onto the box surface before extruding it. Also keep in mind that all fonts are not created equal. In this example I switched to Arial because the default font produced jagged artifacts. ap_carve_letter_equal_extrusion.hipnc Edited April 15, 2022 by Atom 2 Quote Link to comment Share on other sites More sharing options...
bentraje Posted April 16, 2022 Author Share Posted April 16, 2022 I ended up going for @Atom's solution by using ray sop. It was straightforward enough and works as expected. Thanks for the github referral by the way @Librarian. Just checked it and it contains a lot of gems. Quote Link to comment Share on other sites More sharing options...
