How to drive activation with SOP ?
Say I have a RBD Packet Object and a bunch of obstacles to jump over
I have a velocity Impulse force that needs Activation set to 1 at various locations in space and maybe a direction , i.e a bit before the object reaches the obstacle.
In DOP, how do I get those values from a SOP context ?
I would like to set some points and vectors somewhere, and use those as an indication as to where and how much the object should jump
Edited by AntoineSfx
2 hours ago, bentraje said:
Uhm. How about animating the @active attribute?
@active=0 means no simulation while @active=1 means the simulation will take over.
Because I don't know when it needs to be active.
I only know where it needs to be active, i.e as some information in SOP.
5 hours ago, bentraje said:
RE: I only know where it needs to be active, i.e as some information in SOP.
I mean you can just place a bounding box or any geometry where it needs to be active and maybe attribute transfer from @active=0 to @active=1?
you can't attribute transfer in DOP, and in SOP upstream from dopimport, it's a fixed object.
SOP Solver DOP, Geometry Wrangle or Geometry VOP are your main ways of referencing data from SOPs inside of your simulation.
