chluaid 0 Posted June 12 Hi, I'm new to Solaris and Karma, but does Karma xpu allow embedded transparency from textures? I've run into an issue rendering textures with embedded transparency. My example is a tattered cloth texture, where the tatters and holes in the texture are rendering fine with Karma cpu, but not with xpu. I've tried a number of variations using the principled shader in combination with Mtlx tiledimage but to no avail. Again, this renders fine in Karma cpu, but could someone please outline the workflow for this in Karma xpu? Thank you! Share this post Link to post Share on other sites
