Flip narrow band doesn't work with reseeding/ reseeding messes up retime
justinngjw
Hey there,
I'm trying to do some slow-motion with my flip sim and realize that reseed particles are messing up the retime due to its nature to generate new particles every few frames. However I cannot disable reseeding because i'm siming my flip with Narrow Band. is there a way to tackle this without disabling Narrow Band or is there a way to somehow set a fix number of particles and set-id so the sim won't get  mess up when im trying to retime it?
  On 6/15/2022 at 3:57 PM, tamagochy said:
Enable add id in flip solver on particles motion tab. And use id attribute with retime
Hey! yes I’ve did that, but the problem is because reseeding are enable, it causes the point and id to shift regularly.
this problem can be fix by turning off reseeding, but narrow band doesn't allow me to disable reseeding.
Edited by justinngjw
a more detail reply
  On 6/16/2022 at 4:32 AM, Benyee said:
or post your file of simple version?
sure, heres the file with a flipbook.
notice how the reseeding takes effect in frame 33
thank you
Retime_With_Narrowband.mp4Fetching info...
NarrowBand_Reseed.hipncFetching info...
you almost got the way, just try setting "birth threshold" to 0 on flip solver
NarrowBand_Reseed_fix_od.hipncFetching info...
sometimes this kind of issues are knotty, generally we can adjust reseeding paramaters,
some lower birth thresholds, higher death thresholds, and lower surface oversamplings, or other parameters, depends on your effect needs
and also, increasing flip resolution is important for decreasing the popping effects
hey, thanks for the suggestion! however it doesn't seems to work. if you look at the geometry spreadsheet, the id and ptnum are still shifting along with the frame moving forward.
From the file you give, after retime, the particles are still shifting. you can see the first shifting in frame 33
I need the particle id to stay the same throughout the sim.
I've tried to revisit the parameters as you suggest, but I still can't find anything affecting the reseed.
