pyro and volume rasterize attribute
Hi Guy,
There is any magic formula to use between the pyro source; volume rasterize and  smoke objet volex size? I use a scatter point just before the pyro source.. The main problem arrived when I lower the voxel size of the smoke object, I have no more smoke or fire..
What's wrong?
as we can see,they're some channel refs,suggest you break those connection and set them one by one,then check the data flow step by step;
and,why did you put scatter point operation before pyro source,pyro source can scatter pts by itself?for this i'm not sure because i cann't see the data.
so recommndation is check you rdata carefully again,cheers
In this kind of situation I rather rasterize with vdb from particles and play with noises to get the values I want. vol rasterize can be unstable depending on your point count, while vdb from particles will always stay between 0 and 1 so that's cool for this.
