WW emission from EVERYWHERE
5DNick
Hey ODForcers,
I have a FLIP sim and WW, and it was working but now it just emits from the whole FLIP, when it didn't before. It seems to be from Vorticity AND Curvature and makes NO SENSE!
I'm trying everything but wonder if there's something obvious I've overlooked.
I would upload .hip but there are multiple caches ... so ...
Any help much appreciated.
Thanks
Nick
NB: it seems to happen when everything has ZERO vorticity too AND when you turn up vorticity range to say 3000 to 5000
Edited by amaviztime
Unable to guess without a file to dig into, but one suggestion is to reduce your sim size down to a very small region that is quick to simulate/iterate on but still exhibits the behavior.  At least that way you have less data (and sim time) to deal with while troubleshooting.
The main problem I see in your setup is your scaling of time. In my observation, ScaleTime in Houdini simulations can't be pushed more than +/-50% of real-time. You have it set to 0.05. That's not going to work. Just simulate at real time and increase your animation length as needed to slow down your footage later. It's easier to slowdown a longer piece of footage than to speed up a shorter one. You also have collision scale set to 30, which is ridiculously high. Try changing these values back to their default settings.
Edited by Atom
