archz2 Posted October 3, 2022 Share Posted October 3, 2022 I am trying to import a pyro simulation in a sop network using dop import node but unable to do so. What should I do? dop smoke import question.hip Quote Link to comment Share on other sites More sharing options...
fencer Posted October 3, 2022 Share Posted October 3, 2022 Use dopimportfield instead of. 1 Quote Link to comment Share on other sites More sharing options...
archz2 Posted October 4, 2022 Author Share Posted October 4, 2022 (edited) 17 hours ago, fencer said: Use dopimportfield instead of. Still not happening. I did the referencing like this. Please share a screenshot and steps of how to do it. dop smoke import question.hip Edited October 4, 2022 by archz2 Quote Link to comment Share on other sites More sharing options...
haggi Posted October 4, 2022 Share Posted October 4, 2022 The Dop Node parameter should be set to the dop object node, in your case the node named "Pyro". 1 Quote Link to comment Share on other sites More sharing options...
archz2 Posted October 4, 2022 Author Share Posted October 4, 2022 3 hours ago, haggi said: The Dop Node parameter should be set to the dop object node, in your case the node named "Pyro". Done. Still blank. Quote Link to comment Share on other sites More sharing options...
fencer Posted October 4, 2022 Share Posted October 4, 2022 29 minutes ago, archz2 said: Done. Still blank. dopimportfield required fields to import. There are presets option already prepared. 1 Quote Link to comment Share on other sites More sharing options...
archz2 Posted October 4, 2022 Author Share Posted October 4, 2022 Thanks a ton! It worked! Quote Link to comment Share on other sites More sharing options...
