Rebar direction
I have normals following each other. The distance between two points is kept in the @perimeter attribute. I want @N to unfollow when @Perimeter crosses the distance I set.
I did a setup but it doesn't work properly @N direction keeps changing.
Scene file:   N_direction.hiplc
Edited by apollo11
Take perimeter or Vertex beetwen only 2 points of that Line and promote to Gradient middle, or same Chess tex, make to class and random threshold with constant anime B spline, or some Nice Spline :P to chops and Back.  or use This Shortcut 'Ex'  With Vellum( Don't know About Vellum ..Nada...) . just onooo:ph34r:...Maybe it Helps !!
set_emi.hipnc
  • 4 weeks later...
