Creating a mask
PVok
Hello friends.
I wanted to ask you how you would approach solving such a task?
There is a model with uv, divided into hard/soft edge, smoothing groups.
It is necessary to make a mask on the hard edges of the normals. And output the mask via uv.
Uv should not change.
Any ideas on this? Thanks.
On 07.12.2022 at 18:10, hannes603 said:
maybe like that ? :)
Thanks, but not really. I would like to extract normals from the imported geometry without assigning them, and the chamfer only works well with simple geometry, with complex geometry it breaks.
On 09.12.2022 at 12:43 PM, vicvvsh said:
what attributes except uv imported model has? What mask do you want to get - color or just attribute 0-1. And it is not clear for me what "...output the mask via uv" mean.
Uv and normals. The attribute would be enough. Ideally, a black and white mask. Output in the sense of rendering as a 2d mask.
On 09.12.2022 at 12:22 PM, hannes603 said:
i guess you might provide more info to it , otherwise it ll be difficult to help.  First tell us what exactly you want to do. Sometimes people just use wrong aproach in the first place..
Create a tool that generates a skew maponly not from the edges of the uv, but on the edges of the smoothing groups. Used for baking normals.
Edited by PVok
6 hours ago, vicvvsh said:
The normal vectors of vertices of a point, that located on a hard edge, are not coplanar, so this feature i used to find hard edges on a geometry. For visualization purpose i divided low poly geo.
Yes, that's what I need. Thank you very much!
17 hours ago, hannes603 said:
vicvvsh   . why so compicated? just a group node with maximum angle does exactly the same ... but nice script..
Thanks. Yeah, complicated a little, but not the same really.  Try to choose universal value of that angle to use it in for loop, for example, or select all hard edges on a geometry in this attached file.
mask_hard_edges_easygoing_01.hipnc
Thats true... your setup is runnig over normals, which is even better for more control... :)
