Masoud Posted December 30, 2022 Share Posted December 30, 2022 Hi guys I would like to retrieve the temperature field, from the curvature field of the density. It seems the "Gas calculate" node can be applied to turning the curvature into -> temperature, but I don't know how to use this DOP node... I would appreciate any helps and ideas. Thanks Quote Link to comment Share on other sites More sharing options...
uakin Posted December 30, 2022 Share Posted December 30, 2022 you can use "gasanalysis node" to calculate "curveture" in dopnet Quote Link to comment Share on other sites More sharing options...
Masoud Posted December 30, 2022 Author Share Posted December 30, 2022 Hi Uakin, Thank you, but I don't know how to use "Gas analysis ", too. Can you send me a tutorial link or an example file? Gas Analysis_01.hip Quote Link to comment Share on other sites More sharing options...
uakin Posted December 30, 2022 Share Posted December 30, 2022 1 hour ago, Masoud said: Hi Uakin, Thank you, but I don't know how to use "Gas analysis ", too. Can you send me a tutorial link or an example file? Gas Analysis_01.hip 3 Quote Link to comment Share on other sites More sharing options...
Atom Posted December 31, 2022 Share Posted December 31, 2022 @uakinThanks for the setup tips. I've never tried to modify temperature after the fact. What I discovered is that if you omit the temperature field or initialize it with zeros, the Gas Calculate Multiply produces nothing which makes sense. Value times zero. Playing around with the other settings I discovered without a temperature field, a blank one is generated. When I set the calculation method to MINIMUM, the minimum curvature value is supplied as the temperature, and quickly falls in on itself producing a weak bubbling pool or incipient geyser. Could work for bubbling pot, too. 2 Quote Link to comment Share on other sites More sharing options...
Masoud Posted January 1, 2023 Author Share Posted January 1, 2023 Thanks, guys, very helpful tips. Quote Link to comment Share on other sites More sharing options...
