HM_2020 Posted January 17, 2023 Share Posted January 17, 2023 Maybe I have turned on/off a setting by accident? Double checked and nothing pinned, nothing crazy. But some strange reason, and I swear since 18.5+ Houdini seems to want to re cook something that it should not. A simple example - If I convert something to vdb, and then smooth it, and below it put a filecache... before if you had just baked to vdb and then displayed the smooth and then go to save filecache, it didnt rebake the vdb or smooth node above.. but now does... and its really such a time suck repeatedly rebaking. Feels like something post 18.5.... Cheers! Quote Link to comment Share on other sites More sharing options...
Atom Posted January 17, 2023 Share Posted January 17, 2023 (edited) Hmm, I'm not seeing that in H19.5.435. Can you post an example HIP? This HIP generates a high resolution VDB, caches it and then animates the cached frame. I receive no upstream cooks during this process. ap_vdb_verify_upstream_cook.hiplc What if you tried something like this as a workaround. Link a two-state switch to the Load File Cache switch to force everything upstream to essentially be a NULL? Edited January 17, 2023 by Atom 1 Quote Link to comment Share on other sites More sharing options...
ryew Posted January 17, 2023 Share Posted January 17, 2023 (edited) I see this same issue; it was a problem in earlier versions of Houdini that I thought had finally been resolved for good in H19, but nope, now it's back for me with 19.5.435. I can confirm it's extremely aggravating to be trying to work in a scene and have unselected and undisplayed nodes cooking their networks for no apparent reason. Frankly, it makes me want to just revert back to H19.0 Edited January 17, 2023 by ryew 1 Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted January 17, 2023 Author Share Posted January 17, 2023 Cheers Atom, work files unfortunately, will try home later. Cheers Ryew, any chance you have a demo scene that shows it? Good to hear it IS happening to others. Swear it started after 18.5. Quote Link to comment Share on other sites More sharing options...
ryew Posted January 18, 2023 Share Posted January 18, 2023 Likewise all in work scenes, unfortunately. I'll have to see if I can reproduce it at home in a less-complicated setup. It was definitely an issue across multiple earlier versions of Houdini, I don't recall which, but I feel like the range was somewhere in H17 up to about H18.5 as you note, and our entire team was seeing it. I never experienced it in any H19.0 build at all that I can recall, but it quickly became apparent again when I moved to H19.5 Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted January 18, 2023 Author Share Posted January 18, 2023 Well actually its opposite for me, was fine until 18.5... 19+ it seems to be happening. Quote Link to comment Share on other sites More sharing options...
ryew Posted January 19, 2023 Share Posted January 19, 2023 Hmm. I'll go back and check in a 19.0 session; I've been deep in 19.5 for awhile now so I may be mistaken Quote Link to comment Share on other sites More sharing options...
