How to calculate edge normal like PolyExtrude
bastian
Hello there!
How would you calculate the vector depicted as the red arrows in the image.
PolyExtrude node uses it when given an unshared edge group.
I've tried a polyframe's tangentu and tangent crossed in vex with the Normal. Without luck.
It doesn't seem to be just a continuation of each points inner edges (the not unshared ones.... :/ ). But can't wrap my head around where to go with it.
Thanks
Edited by bastian
@bastian
Prim wrangle (tangent)
int vtc[];
vtc = primvertices(0, @primnum);
int n = len(vtc);
int jm1, j, jp1;
int pm1, p, pp1;
vector A,B;
for (int i = 0; i < n; i++)
    jm1 = i - 1;
    j = i;
    jp1 = i + 1;
    if (chi('mode') == 0)
        jm1 %= (n-1);
        jp1 %= (n-1);
    } else
        jm1 = max(0, jm1);
        jp1 = min(n-1, jp1);
    pm1 = vertexpoint(0, vtc[jm1]);
    p = vertexpoint(0, vtc[j]);
    pp1 = vertexpoint(0, vtc[jp1]);
    A = point(0, 'P', p) - point(0, 'P', pm1);
    B = point(0, 'P', pp1) - point(0, 'P', p);
    setpointattrib(0, 'tangentu', p, normalize(lerp(A, B, 0.5)));
Point wrang-set normal by tangent
vector up = chv('up');
v@N = normalize(cross(v@tangentu, up));
if (chi('reverse'))
    v@N *= -1;
So I tried your suggestions and both don't work on corners and place where two edges meet, or on edges "facing upwards".
The picture in the post doesn't quite show how inconsistent the mesh is. My mistake.
I've done another pretty "hacky" way of just doing a extra PolyExtrude, wrangle a vector to the extruded edge.
But can imagine it breaking easily with a denser mesh.
I can definitely work with the results here, but would love a consistent method as it isn't the first time I've come across this problem.
Thanks again!
Edited by bastian
comprehension
it seems to work this way:
For each point -> loop over all neighbours where the edge is an open edge. Calculate the cross product of the normal (of incident primitive of the half-edge) and the half-edge direction. Take the average of both normals.
VectorFromPolyExtrude_mod.hipncFetching info...
Edited by Aizatulin
  • Thanks 1
