Guna Posted March 23, 2023 Share Posted March 23, 2023 (edited) Hi everyone, Any idea how to apply ocean spectrum to a tube shape. Need the spectrum along the direction of the normal. Appreciate any help. Thanks Oceanspectrum01.hipFetching info... Edited March 23, 2023 by aaryanguna Quote Link to comment Share on other sites More sharing options...
mrCatfish Posted March 27, 2023 Share Posted March 27, 2023 This is covered thoroughly in this Masterclass, (vid will be cued to correct time): 2 Quote Link to comment Share on other sites More sharing options...
Atom Posted March 27, 2023 Share Posted March 27, 2023 Thanks for that link Sean. I've never played around with the instance tab before. It looks like you can put an ocean on anything, then path deform it later. 3 Quote Link to comment Share on other sites More sharing options...
Guna Posted March 29, 2023 Author Share Posted March 29, 2023 (edited) Thank you Sean and Atom. I just checked the link and tried the wave instancing. Still I dint find the option to get the spectrum along the normal. they are oriented to Y axis only. Any help? Edited March 29, 2023 by aaryanguna Quote Link to comment Share on other sites More sharing options...
mrCatfish Posted March 30, 2023 Share Posted March 30, 2023 Just applying a normals sop should do it... twistedOcean.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Guna Posted March 31, 2023 Author Share Posted March 31, 2023 On 3/30/2023 at 1:10 PM, mrCatfish said: Just applying a normals sop should do it... twistedOcean.hipnc 294.41 kB · 3 downloads Expand Thanks for the reply Sean. I don't think adding normals sop has fixed the issue. I have taken a snapshot from the file you sent. Although I have come at an alternate solution using mountain sop I am curious to know how to achieve it using ocean spectrum. Quote Link to comment Share on other sites More sharing options...
HM_2020 Posted March 31, 2023 Share Posted March 31, 2023 On 3/31/2023 at 2:39 PM, Guna said: Although I have come at an alternate solution using mountain sop I am curious to know how to achieve it using ocean spectrum. Expand Well, whats your solution? Quote Link to comment Share on other sites More sharing options...
Guna Posted April 1, 2023 Author Share Posted April 1, 2023 On 3/31/2023 at 9:42 PM, HM_2020 said: Well, whats your solution? Expand Its just mountain sop with twist and edge color sop to get the color on cusp Quote Link to comment Share on other sites More sharing options...
Atom Posted April 1, 2023 Share Posted April 1, 2023 I had to try building that. Here's my setup. Now if there was a way to get whitewater to show up on those cresting waves..? ap_ocean_tube_040123.hiplcFetching info... 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 2, 2023 Share Posted April 2, 2023 @Atom Nice 1 Quote Link to comment Share on other sites More sharing options...
Guna Posted April 3, 2023 Author Share Posted April 3, 2023 On 4/2/2023 at 4:24 PM, Librarian said: @Atom Nice Expand Looks nice.. could you please explain the set up? Quote Link to comment Share on other sites More sharing options...
