Coz_y_not Posted April 17, 2023 Share Posted April 17, 2023 (attached hip file) Is there a way to drive the scale of the fractured piece with pscale from scattered points? all I'm trying to do is randomise the scale of each fractured piece between 0.1 and 2 pscale_in_voronoi_fracture.hiplc Quote Link to comment Share on other sites More sharing options...
Atom Posted April 17, 2023 Share Posted April 17, 2023 I don't think it works that way. If you're trying to break up the uniform voronoi pattern, lower the count on the scatter and drop down a point replicate after. Set the point replicate to a small count value and scale the clusters out a bit. This will give you a cluster of points at each fracture section. This helps generate size variations in the final fracture pieces. Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 17, 2023 Share Posted April 17, 2023 One Way @karen 1 Quote Link to comment Share on other sites More sharing options...
