Daniel16_16 Posted June 2, 2023 Share Posted June 2, 2023 Hey folks, I am trying to create a rocket engine thruster effect. I already have done some work, but at one point, I can't understand how to continue from there. What I've done so far: - I created a line - added a sweep node which creates a tube - Then I used the scale option in the sweep node to create the rough shape of the exhaust. - After that I scattered some points on the geometry and added the attribute noise node to wiggle the points. - After that I added the volumerasterizeattributes1 node to create a volume out of those points. Now, the main problem is, that the rasterization is kinda messed up and there are gaps in between (seen in the attached screenshot): I want to create something like that: - my problem is, I don't know how to achieve that smooth looking result like in the reference picture: (up) Some folks have told me to create the exhaust shape with geometry and then with the VDB from polygons node to turn the geometry into volume. I tried it out and I get the base volume shaped exhaust but I don't know how to add some noise to wiggle the volume or something like that. Now, I am asking here, if someone could help me and tell me what I am doing wrong and what I could do instead. Thanks in advance Daniel Quote Link to comment Share on other sites More sharing options...
Atom Posted June 2, 2023 Share Posted June 2, 2023 Try focusing on the rendered output, not the viewport. You could try VDB smoothing along the axis of projection or supply a velocity field for volume based motion blur. 1 Quote Link to comment Share on other sites More sharing options...
Daniel16_16 Posted June 2, 2023 Author Share Posted June 2, 2023 On 6/2/2023 at 12:59 PM, Atom said: Try focusing on the rendered output, not the viewport. You could try VDB smoothing along the axis of projection or supply a velocity field for volume based motion blur. Expand Ah yea, I forgot to mention: I will be exporting it to Blender as a VDB sequence. I won't be rendering it in Houdini as I have the apprentice version of Houdini. Quote Link to comment Share on other sites More sharing options...
