Sequence of deforming geometies, from Houdini into 3dsmax, issue!
Masoud
Hello guys,
First I imported an object from 3dsmax into Houdini and after fracturing and simulating, now I would like to import the result (sequence of animated geometries) back again into 3dsmax. I tried to use Alembic and FBX, but the result is not satisfying, because it destroys the material IDs.
What is the best workflow in this situation?
Thanks for helping.
