Teteerck Posted September 7, 2023 Share Posted September 7, 2023 (edited) Hi everyone! Houdini noob here. Hopefully i can get some help hehe i know this is the forum of Houdini pros. Thank you so much in advance for any help/guidance you can give. I'm trying to make some vellum cloth floating, but i want to do an animation where it just loops floating. This is what i tried. It's practically working fine BUT after i use Labs make loop some parts of the geometry starts intercepting it self, i guess it kind of makes sense, but i was wondering if there's any way to prevent this from happening or there's is different way of achieving this that doesn't produce that problem? Thank you so much!! fingers crossed hehe there's a hip attached in case it's helpful Cloth Test3.hiplc Edited September 7, 2023 by Teteerck Quote Link to comment Share on other sites More sharing options...
Drunkenpanda Posted September 7, 2023 Share Posted September 7, 2023 Not sure what the node does, but you can try match size combined with a blend shades node of the cloth going in the other direction in time and mainly key frame. Quote Link to comment Share on other sites More sharing options...
