MtlX Two Sided material
Hello,
I am trying to replicate the Principled Shader setup with MaterialX and can't get it working.
I see 2 issues:
  • the "bind" node doesn't read "pagea" and "pageb" attributes (string path to the texture files, e.g. E:/textures/page_1.jpg) defined in SOP context
  • twosided node is not working with material X
If you assign "/materials/page_principal" material shader will work, "/materials/page_mtlx" - no.
book_flip_pages_008.hiplc
Why can't I create a "USD Prim Var Reader" node in the "USD MaterialX Builder" context?
But I can create this node in the "USD Preview Material Builder" context and then copy-paste it to the USD MaterialX Builder.
Why if I connect the "USD Prim Var Reader" result to the "MtlX Image" file, it also affect the signature? How can I break the connection to the signature?
It is also giving an error: Input storage type (uniform/varying) does not match input 'file'.
