Masoud Posted April 16, 2024 Share Posted April 16, 2024 Hi guys, I want the background image be visible in the object's refraction, so I add my desired image to a "Background Plate" LOP, and to my camera background Image file tab too, but it doesn't work! How can I fix it? Thanks for helping. Quote Link to comment Share on other sites More sharing options...
Masoud Posted April 17, 2024 Author Share Posted April 17, 2024 Any ideas? Quote Link to comment Share on other sites More sharing options...
TobyGaines Posted May 26, 2024 Share Posted May 26, 2024 The transparent shader and the render settings will need to be set up properly - can you share them I've never used the background plate lop, but if all else fails you may need to go inside of it to make sure it's visible to refraction rays, or maybe an object settings node will let you add that Quote Link to comment Share on other sites More sharing options...
