Flip-Fluid Invert-Sign volume issue..!
Masoud
Hi guys,
In a Flip-Fluid simulation, I want the fluid particles to enter and trap in a closed collision volume (I mean an Invert-Sign volume).
I applied these settings:
1) "Static Object->Collisions->Volume->Invert Sign" to on.
2) "Flip Solver->Volume Motion->Collisions-> Transparency" to on.
3) "Flip Solver->Volume Motion->Collisions-> Transparency" value to 1.
As you can see in my preview video below, the fluid flows strangely!
How can I fix it?
Thanks for helping.
Fluid_Invert Collision_01.hip
I turned the "Volume Motion->Collisions->Surface Extrapolation" to zero and now the fluid motion is better, outside of the collision volume.
There is still a gap between the fluid and an invisible bounding box around the collision geo.!
And the fluid sinks!
Somewhere along the line since H16, when the file was authored, a bug was fixed that requires new flip points to actually exist in group named "particles". Try adding a group name to the particles supplied to the source volume node.
