amirrasta Posted June 17, 2024 Share Posted June 17, 2024 Hi I have a box that I have animated, and the simulation supposed to be like the water should start from down to fill the box and the box should be filled for 50 frames then the box starts to rotate after the rotation the box must get empty. THATS THE ALL SIM ANIMATION PART. My problem is: 1- when the box is almost full of water, I couldn't keep the water level as it is, I try to keep it by animating divergence but sometimes it's getting too much or sometimes it's getting less. 2- I try to make the box empty but still some water will leave at the end, how can I fix that. 3- at the end you can see some particles are getting white and sometimes getting out of the box, I really don't know why this happen. I am sharing the Houdini file, preview and the frame which particles are getting white. I REALLY APPRECIATE IF YOU COULD HELP ME. TEST_V017_[1-300].mp4 FOR TEST.rar Quote Link to comment Share on other sites More sharing options...
dleonhardt Posted June 17, 2024 Share Posted June 17, 2024 I marked all the nodes of interest in red and left some sticky notes. dl_BOX_test_02_V017.hipnc 2 Quote Link to comment Share on other sites More sharing options...
amirrasta Posted June 17, 2024 Author Share Posted June 17, 2024 (edited) I really appreciate your help. thanks a lot Edited June 17, 2024 by amirrasta Quote Link to comment Share on other sites More sharing options...
hannes603 Posted June 17, 2024 Share Posted June 17, 2024 untitled.mp4 fliptest.hip maybe you can also animate the source if possible like here 1 Quote Link to comment Share on other sites More sharing options...
