movie: Construction-plane modeling
Jason
Hi all,
I have been mulling over modeling using the Construction Plane - to take advantage of this unique tool in Houdini. I see a lot of potential with mastering the Plane - does anyone else here have special ways to manipulate the Construction Plane?
So I made a quick movie of what I thought was a single good use for the Plane during modeling - drawing and editing aligned to arbitrary faces.
Imagine my sphere in the video was a spaceship and I had to model portholes.. here it'd be very handy...
Please look at my movie.. HERE!
(No audio: In the movie I am hitting "c" to start orientation picking of the Plane.)
Cheers,
Jason.
PS. I wish I could use a better format, but Peter is right - Realplayer is the only thing to run on all platforms. Unless every agrees to use ASF or WMV?
What do you all think? Which one is best value for badwidth?
Well that was fast!!!! and you're right, WMV is clearer and a few times faster for downloading. As for the lack of audio I think doing things where all your moves are pretty much visible in the viewport is fine, people get the idea. Pop-up menus also help.
Hopefully the first of many videos to find their way to this site.
Betty
btw, of course you got me thinking about the construction plane, i'll be getting onto it asap.
Jason
Still have a bit of a problem with the constuction plane.
How 'bout being able to draw on a surface, that way you don't need to pick another orientation for your plane as you had to when wanting to draw that arrow-like shape and having to get the construction plane aligned onto the other primitive?
What do you think?
Betty
You actually can draw on a face, using "Snap" and under Options, set it to Primitive. You can draw directly on surfaces, although I think a bug in Houdini 5.0 made it hard to draw on polygonal faces. This works juuuust fine in 5.5 :)
So you're right, this functionality makes my example a little redundant. Perhap the CPlane can be used more for lining up transforms to arbitrary axies? I know that Maya has a neat thing with its handles where you can snap in one axis only: .i.e snap to bounding extents in one of the orthographic views at the hold of a button. Do you know what feature I'm talking about? Or should I give an example?
Whohooo! I was wondering about that a few months back. Complete forgotten to try this in 5.5. Sweet to hear it works in 5.5. :)
Jason
Good to hear that drawing on a poly object is supported.
Please note, a lot of my comments are about the construction plane as a tool for poly modeling. I'm sure it does well in other areas ( areas which i haven't gone yet in Houdini. )
Yeah, i've used those snapping tools in Maya and they are pretty cool.
I'll give the construction plane a good work out in the next week.
Yep - it's great now that it's working so well. I think it still works fine for Houdini 5.0 with parametric surfaces.
I like to hear some of your experiences with the CPlane when you get around to it. It's one of those things where I am sure it can be invaluable but I can't think of quite how.
Sunny days,
J
  • 7 years later...
  • 1 month later...
I don't get this. Propably something has changed from H5.5 but even with help I can't get it to work. Hm.
haha.. I suspect something may have changed :D. I just put it up for old times' sake, I'm sure things have changed drastically since then.
Yes, unfortunately the construction plane as it is configured now is pretty much useless as a modelling tool. I wish it weren't so, but gaining control of the construction plane to move it around and snap to surfaces and such is extremely awkward. I would certainly like to have a good, intuitive construction plane to use.
I'm old fashion, but the construction plane in the model sop was way better and I used it alot.
  • 2 weeks later...
  • 11 months later...
