mois23 Posted yesterday at 09:18 AM Share Posted yesterday at 09:18 AM (edited) Hey everyone I'm stuck on a really simple problem that I can't seem to figure out how to solve. I have a group of points, each of which has a float speed and a direction: f@speed and v@dir. I would like Houdini to identify i@clusters based on the direction orientation and the speed value. Basically I want to iterate the code over all the points: if the angle formed by the dir vectors is less than a certain threshold, the code also checks the speed value. If the speed difference is also less than a certain threshold then those points are part of the same cluster (see attached image). I tried a code, where at each iteration I identify the neighboring points and if they are found then it removes them from the iteration queue to avoid infinite loops. But the clustering does not work, when I change the value of speed threshold and angle threshold I get no change. This only happens if I change search radius. Am I missing something? clusterbyattribute.hip Edited yesterday at 10:20 AM by mois23 Quote Link to comment Share on other sites More sharing options...
mois23 Posted yesterday at 10:32 AM Author Share Posted yesterday at 10:32 AM I reviewed the code and I think I made some mistakes. The second condition, the speed difference check, I put it after the angle difference condition is verified. It works better now. What do you think? clusterbyattribute2_fix.hip 1 Quote Link to comment Share on other sites More sharing options...
Librarian Posted 23 hours ago Share Posted 23 hours ago @mois23 Try this maybe you can get some idea's. https://scikit-learn.org/dev/modules/generated/sklearn.cluster.AgglomerativeClustering.html + files https://github.com/Fe-Elf/FeELib-for-Houdini Quote Link to comment Share on other sites More sharing options...
