Jim Su Posted September 7, 2007 Share Posted September 7, 2007 I tried to write the geometry out as .gz but that didn't work. Thanks Jim Quote Link to comment Share on other sites More sharing options...
Jason Posted September 7, 2007 Share Posted September 7, 2007 I tried to write the geometry out as .gz but that didn't work.Thanks Jim If you save your geometry as .bgeo.gz it should work. You can gzip a .bgeo after you've written it out too, by the way - as long as it ends up in the naming convention of filename.bgeo.gz Hope this helps, Jason Quote Link to comment Share on other sites More sharing options...
michael Posted September 7, 2007 Share Posted September 7, 2007 I think Jim misses C.O.R.E. Quote Link to comment Share on other sites More sharing options...
Jim Su Posted September 7, 2007 Author Share Posted September 7, 2007 If you save your geometry as .bgeo.gz it should work. You can gzip a .bgeo after you've written it out too, by the way - as long as it ends up in the naming convention of filename.bgeo.gzHope this helps, Jason Thanks Jason! Yes, that worked. I just realized gzbgeo is a C.O.R.E. suffix. And Arctor, I've been freakin' building VOP SOP modelling tools that I miss at CORE, but no luck building arctor.otl . Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted September 7, 2007 Share Posted September 7, 2007 (edited) Thanks Jason! Yes, that worked. I just realized gzbgeo is a C.O.R.E. suffix. Useless Trivia: The whole reason I did the .gzbgeo extension instead of .bgeo.gz was so that the .gzbgeo entry would show up in the pop-up list of 'known' file extensions in the Save As dialogs. I regret nothing! {edit: I speelz gud} Edited September 10, 2007 by Wolfwood Quote Link to comment Share on other sites More sharing options...
Jason Posted September 8, 2007 Share Posted September 8, 2007 Useless Trivia:The whole reason I did the .gzbgeo extension instead of .bgeo.gz was so that the .gzbgeo entry would should up in the pop-up list of 'known' file extensions in the Save As dialogs. I regret nothing! A good reason indeed - since I've run into that myself:) Have you reported that one to SESI? I thought of telling them but I've been getting RSI from the number of mails I've been sending lately. Quote Link to comment Share on other sites More sharing options...
Jenny Posted September 10, 2007 Share Posted September 10, 2007 A good reason indeed - since I've run into that myself:) Have you reported that one to SESI? I thought of telling them but I've been getting RSI from the number of mails I've been sending lately. Jason, are you still having trouble contacting SESI? If so, please e-mail Support@SideFX.com. Thanks, Jenny. Quote Link to comment Share on other sites More sharing options...
