Masoud Posted March 27, 2025 Share Posted March 27, 2025 Hi guys, I need to create a vector attribute, where all the vectors are aligned along the tangent of the surface, while also pointing toward a specified target point. I believe that combining the Tangent-field SOP with the Normal vector attribute should provide the solution, but I'm not sure how to properly blend them together! vector target_pos = point(0, "P", 66); vector normal = normalize(@N); vector tangent = v@field1; vector dir_to_target = normalize(target_pos - @P); v@FinalVect = ? Thanks for helping. TangetntField_01.hip Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted March 27, 2025 Share Posted March 27, 2025 Hi you can project the direction onto the surface using the Y-direction for example. TangetntField_01_mod.hipnc 1 Quote Link to comment Share on other sites More sharing options...
haggi Posted March 27, 2025 Share Posted March 27, 2025 Or without a double intersect call: vector A = point(0, "P", 66); vector B = normalize(A-v@P); vector C = v@P + B * .1;// 0.1 to avoid overshooting int prim; vector primuv; xyzdist(0, C, prim, primuv); vector surfaceP; prim_attribute(0, surfaceP, "P", prim, primuv); v@field1 = normalize(surfaceP-v@P); 3 Quote Link to comment Share on other sites More sharing options...
satoru Posted March 28, 2025 Share Posted March 28, 2025 (edited) I usually do it like this. gradient.hiplc Edited March 28, 2025 by satoru 6 Quote Link to comment Share on other sites More sharing options...
haggi Posted March 28, 2025 Share Posted March 28, 2025 Houdini has sooo many cool nodes, thanks for sharing the file. I learn new things every day. 1 Quote Link to comment Share on other sites More sharing options...
