Following surface tangent, pointing to a target, issue..!
Hi guys,
I need to create a vector attribute, where all the vectors are aligned along the tangent of the surface, while also pointing toward a specified target point.
I believe that combining the Tangent-field SOP with the Normal vector attribute should provide the solution, but I'm not sure how to properly blend them together!
vector target_pos =  point(0, "P", 66);
vector normal = normalize(@N);
vector tangent = v@field1;
vector dir_to_target = normalize(target_pos - @P);
v@FinalVect = ?
Thanks for helping.
TangetntField_01.hipFetching info...
Or without a double intersect call:
vector A =  point(0, "P", 66);
vector B = normalize(A-v@P);
vector C = v@P + B * .1;// 0.1 to avoid overshooting
int prim;
vector primuv;
xyzdist(0, C, prim, primuv);
vector surfaceP;
prim_attribute(0, surfaceP, "P", prim, primuv);
v@field1 = normalize(surfaceP-v@P);
  • Like 3
