gangland Posted April 24, 2025 Share Posted April 24, 2025 Hello guys, I want to grab a deformed geometry, flatten in Y, do some point animation in the flatten area, then return the animated in 2d space to original geometry. I did the flatten geometry, scatter and animated the points on it. But I have no ideia how to trasnfer them the to original position noise_anim_2d_v001.hiplc Quote Link to comment Share on other sites More sharing options...
Sepu Posted April 24, 2025 Share Posted April 24, 2025 Multiple ways to do this you could use the minpos, nearpoint, etc functions or use the ray sop for a non-code option. You could also use the UV of the mesh (in other words you unwrapped the UVs, but in 3d space) do the scatter or whatever then bring back using the xyzdist function to find the closest prim, and the uv position within that prim. 1 Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted April 25, 2025 Share Posted April 25, 2025 Hi, ray sop + primuv() or ray sop + attribute interpolate sop can do it noise_anim_2d_v001_01.hipnc Quote Link to comment Share on other sites More sharing options...
gangland Posted April 25, 2025 Author Share Posted April 25, 2025 9 hours ago, vicvvsh said: Hi, ray sop + primuv() or ray sop + attribute interpolate sop can do it noise_anim_2d_v001_01.hipnc 177.21 kB · 3 downloads Nicee, crystal clear solution, that was exactly that I was looking for, Thaanks man! Quote Link to comment Share on other sites More sharing options...
