line animation
sebastienlevieux
Hello guys,
I tried to create an animation with a curve based on this draw, point moves sequentially toward the next one,  like a folding curtain that retracts point by point. Each point can only move once the previous one has reached its position, and they must never overlap... here is my file.. if you can take a look or if you have any idea for something better
Image: point 1 goes to point 2, then point 1 and 2 go toward point 3....etc...Thanks for helping.
test_anim.hiplc
Edited by sebastienlevieux
// === Parameters ===
float speed = chf("speed");
int start_frame = chi("start_frame");
// === Custom smoothstep function (renamed!)
float my_smoothstep(float edge0, edge1, x) {
    float t = clamp((x - edge0) / (edge1 - edge0), 0.0, 1.0);
    return t * t * (3.0 - 2.0 * t);
// === Point setup ===
int pt = @ptnum;
int frame = int(@Frame);
int offset = pt * 3;
int local_frame = frame - start_frame - offset;
if (local_frame < 0) {
    @P = point(0, "P", pt);
    return;
// === Start/end positions from two input curves
vector start_pos = point(0, "P", pt);
vector target_pos = point(1, "P", pt);
// === Interpolation logic
float dist = distance(start_pos, target_pos);
float travel = speed * float(local_frame);
float ratio = clamp(travel / dist, 0.0, 1.0);
ratio = my_smoothstep(0.0, 1.0, ratio);
// === Apply animated position
@P = lerp(start_pos, target_pos, ratio);
@sebastienlevieux
int pt = @ptnum;
    return;
@sebastienlevieux
Thank you, do you have any explanation?
int pt = @ptnum;
    return;
@sebastienlevieux
For some reason it feels like this was chatGPT.
4 hours ago, sebastienlevieux said:
Hello guys,
I'm not proud of this :D definitely not the best approach, (especially that it doesn't stop at the end :D) but maybe can give you ideas.
curtain_thingy.hiplc
Thanks for your setup, it looks great! But I’m not seeing the same behavior on my end,  in my screenshot, the points are overlapping, which doesn’t happen in your video.image.gif.95d98d54bd8c3e1c1fba1f0de2627d72.gif
3 hours ago, Aizatulin said:
Here are some ideas using this on curves (if I understood correctly)
It is cool! I will explore how you solve it, your setup is completly different than mine, your setup is totally different from mine. Could you explain a bit about your workflow?
Ah sorry, play with this parameter, set it for example -0.1. (i must have changed it after the gif making accidentally)
But i want to emphasize that this method is not the best overall.
Sure :-)
Each point has a position on a curve (called u, which is between 0.0 and 1.0). If you want to move the point, you change this u-value (by input parameter) and read the point again from the curve function (called primuv). If the first point has the position 0.0 and the second point has 0.25, you can move the first point until it reaches 0.25 (but 0.25 is already too much, so you substract a small value for example 0.01). So if the first point reaches 0.24 you start to move the second point (now you are adding the offset 0.01 again, that this point starts from 0.25 (if you input is 0.24)). If you have another (third point), you have substract 0.01 twice because you already have two moving points, so if this point starts from 0.5, it will start if your input u reaches 0.48 (position of the first point and the second point has position 0.49).
In fact you can accumulate over different distances along the points just adding all distances from all points before.
This method won't work, if the points are too close together, compared to defined distance.
If you have smooth curve with a few points you can use a guide curve (with many points) to move the points smoothly just capturing the points on the smooth curve (using xyzdist). For a straight line it doesn't matter you can just use the same curve as guide curve.
shift_points_along_curve_mod.hipnc
