Theophylact Posted January 30 Share Posted January 30 Please help me, how should I approach this geo effect? Let’s take a single line as a base geometry. From this line, generate a new geometry composed entirely of dots. The dot pattern is inspired by fake Morse code: it follows the visual logic of Morse, but only consists of dots with different density. Only dots are used - no dashes. What would normally be a dash is represented as a region of higher dot density (clusters of tightly packed points). Pauses or separations are represented by lower-density or empty gaps - something like that. Any ideas? Quote Link to comment Share on other sites More sharing options...
Librarian Posted January 30 Share Posted January 30 Try to modify something. Quote Link to comment Share on other sites More sharing options...
Librarian Posted January 30 Share Posted January 30 (edited) // DETAIL WRANGLE (run once) // Input 0: a single curve/polyline primitive (uses "prim" parm) // -------------------- Parameters -------------------- int prim = chi("prim"); int seed = chi("seed"); string msg = chs("message"); float unit_len = chf("unit_len"); // unit length in curve-u (0..1) float spacing_units = chf("spacing_units"); // base dot spacing in "units" float dot_mult = chf("dot_mult"); // density multiplier for dot float dash_mult = chf("dash_mult"); // density multiplier for dash (dense dots) float jitter_radius = chf("jitter_radius"); // world-space jitter radius around curve float jitter_along = chf("jitter_along"); // along-interval jitter (0..1) int max_pts = chi("max_pts"); // Morse timing (in units) float dot_units = chf("dot_units"); // usually 1 float dash_units = chf("dash_units"); // usually 3 float gap_symbol_units = chf("gap_symbol_units"); // usually 1 (between . and - in same letter) float gap_letter_units = chf("gap_letter_units"); // usually 3 (between letters) float gap_word_units = chf("gap_word_units"); // usually 7 (between words) // -------------------- Helpers -------------------- function void frame_on_curve(int geoh; int pr; float u; vector up; export vector P; export vector T; export vector N; export vector B) { P = primuv(geoh, "P", pr, set(u, 0, 0)); float du = 1e-4; vector P2 = primuv(geoh, "P", pr, set(clamp(u + du, 0.0, 1.0), 0, 0)); T = normalize(P2 - P); vector a = normalize(cross(up, T)); if (length(a) < 1e-6) a = normalize(cross({1,0,0}, T)); B = normalize(a); N = normalize(cross(T, B)); } function int emit_interval(int geoh; int pr; float u0; float u1; float density_mult; int seedbase; float unit_len; float spacing_units; float jitter_radius; float jitter_along; int max_pts) { float du = max(0.0, u1 - u0); float interval_units = du / max(1e-8, unit_len); float base_count = interval_units / max(1e-8, spacing_units); int npts = int(ceil(base_count * max(0.0, density_mult))); if (npts <= 0) return 0; vector up = {0,1,0}; int created = 0; for (int i = 0; i < npts; i++) { if (created >= max_pts) break; float t = (npts <= 1) ? 0.5 : (float(i) / float(npts - 1)); float r = rand(set(seedbase, i, 19.123)); float u = lerp(u0, u1, t); // jitter a bit along the interval u += (r - 0.5) * jitter_along * (spacing_units * unit_len); u = clamp(u, u0, u1); vector P, T, N, B; frame_on_curve(geoh, pr, u, up, P, T, N, B); // jitter in disk around curve float ang = rand(set(seedbase, i, 3.7)) * 2.0 * M_PI; float rr = sqrt(rand(set(seedbase, i, 8.1))) * jitter_radius; vector jitter = cos(ang) * N * rr + sin(ang) * B * rr; int pt = addpoint(0, P + jitter); setpointattrib(0, "curveu", pt, u, "set"); setpointattrib(0, "pscale", pt, fit01(rand(set(seedbase, i, 77.7)), 0.6, 1.2), "set"); created++; } return created; } // Morse lookup: chars and their morse strings function string morse_of(string ch) { string chars[] = { "A","B","C","D","E","F","G","H","I","J", "K","L","M","N","O","P","Q","R","S","T", "U","V","W","X","Y","Z", "0","1","2","3","4","5","6","7","8","9" }; string codes[] = { ".-","-...","-.-.","-..",".","..-.","--.","....","..",".---", "-.-",".-..","--","-.","---",".--.","--.-",".-.","...","-", "..-","...-",".--","-..-","-.--","--..", "-----",".----","..---","...--","....-",".....","-....","--...","---..","----." }; // already uppercase before calling, but safe: string up = toupper(ch); int idx = -1; for (int i = 0; i < len(chars); i++) { if (up == chars[i]) { idx = i; break; } } if (idx < 0) return ""; // unsupported char -> treat as gap return codes[idx]; } // -------------------- Main: walk along curve-u -------------------- float u = 0.0; int total = 0; msg = toupper(msg); // iterate message characters for (int c = 0; c < len(msg); c++) { if (u >= 1.0 || total >= max_pts) break; string ch = msg[c]; // Word gap if (ch == " ") { u = min(1.0, u + gap_word_units * unit_len); continue; } string code = morse_of(ch); // Unsupported char: treat like a word-ish gap if (code == "") { u = min(1.0, u + gap_letter_units * unit_len); continue; } // For each symbol in morse code for (int s = 0; s < len(code); s++) { if (u >= 1.0 || total >= max_pts) break; string sym = code[s]; float dur_units = (sym == ".") ? dot_units : dash_units; float dens = (sym == ".") ? dot_mult : dash_mult; float u1 = min(1.0, u + dur_units * unit_len); total += emit_interval(0, prim, u, u1, dens, seed + total * 31, unit_len, spacing_units, jitter_radius, jitter_along, max_pts); u = u1; // symbol gap (but not after last symbol) if (s < len(code) - 1) u = min(1.0, u + gap_symbol_units * unit_len); } // letter gap after each character (but not if next is space) if (c < len(msg) - 1 && msg[c+1] != " ") u = min(1.0, u + gap_letter_units * unit_len); } multiple Lines // DETAIL WRANGLE (run once) // Input 0: multiple polyline primitives int seed = chi("seed"); string msg = chs("message"); float unit_len = chf("unit_len"); float spacing_units = chf("spacing_units"); float dot_mult = chf("dot_mult"); float dash_mult = chf("dash_mult"); float jitter_radius = chf("jitter_radius"); float jitter_along = chf("jitter_along"); int max_pts_total = chi("max_pts_total"); // Morse timing (units) float dot_units = chf("dot_units"); float dash_units = chf("dash_units"); float gap_symbol_units = chf("gap_symbol_units"); float gap_letter_units = chf("gap_letter_units"); float gap_word_units = chf("gap_word_units"); // ---------- Helpers ---------- function void frame_on_curve(int geoh; int pr; float u; vector up; export vector P; export vector T; export vector N; export vector B) { P = primuv(geoh, "P", pr, set(u, 0, 0)); float du = 1e-4; vector P2 = primuv(geoh, "P", pr, set(clamp(u + du, 0.0, 1.0), 0, 0)); T = normalize(P2 - P); vector a = normalize(cross(up, T)); if (length(a) < 1e-6) a = normalize(cross({1,0,0}, T)); B = normalize(a); N = normalize(cross(T, B)); } function int emit_interval(int geoh; int pr; float u0; float u1; float density_mult; int seedbase; float unit_len; float spacing_units; float jitter_radius; float jitter_along; int max_pts_cap; int prim_id; int symbol_id) { float du = max(0.0, u1 - u0); float interval_units = du / max(1e-8, unit_len); float base_count = interval_units / max(1e-8, spacing_units); int npts = int(ceil(base_count * max(0.0, density_mult))); if (npts <= 0) return 0; vector up = {0,1,0}; int created = 0; for (int i = 0; i < npts; i++) { if (created >= max_pts_cap) break; float t = (npts <= 1) ? 0.5 : (float(i) / float(npts - 1)); float r = rand(set(seedbase, i, 19.123)); float u = lerp(u0, u1, t); u += (r - 0.5) * jitter_along * (spacing_units * unit_len); u = clamp(u, u0, u1); vector P, T, N, B; frame_on_curve(geoh, pr, u, up, P, T, N, B); float ang = rand(set(seedbase, i, 3.7)) * 2.0 * M_PI; float rr = sqrt(rand(set(seedbase, i, 8.1))) * jitter_radius; vector jitter = cos(ang) * N * rr + sin(ang) * B * rr; int pt = addpoint(0, P + jitter); setpointattrib(0, "curveu", pt, u, "set"); setpointattrib(0, "pscale", pt, fit01(rand(set(seedbase, i, 77.7)), 0.6, 1.2), "set"); // super useful for shading / grouping setpointattrib(0, "sourceprim", pt, prim_id, "set"); // which input curve setpointattrib(0, "symbol", pt, symbol_id, "set"); // 0=dot, 1=dash created++; } return created; } function string morse_of(string ch) { string chars[] = { "A","B","C","D","E","F","G","H","I","J", "K","L","M","N","O","P","Q","R","S","T", "U","V","W","X","Y","Z", "0","1","2","3","4","5","6","7","8","9" }; string codes[] = { ".-","-...","-.-.","-..",".","..-.","--.","....","..",".---", "-.-",".-..","--","-.","---",".--.","--.-",".-.","...","-", "..-","...-",".--","-..-","-.--","--..", "-----",".----","..---","...--","....-",".....","-....","--...","---..","----." }; string upc = toupper(ch); for (int i = 0; i < len(chars); i++) if (upc == chars[i]) return codes[i]; return ""; } // ---------- Main ---------- msg = toupper(msg); int npr = nprimitives(0); int total_pts = 0; // You can choose: same message for every curve, or offset/seed per curve. for (int pr = 0; pr < npr; pr++) { if (total_pts >= max_pts_total) break; float u = 0.0; // per-primitive seed so each curve has a unique pattern jitter int sseed = seed + pr * 10007; for (int c = 0; c < len(msg); c++) { if (u >= 1.0 || total_pts >= max_pts_total) break; string ch = msg[c]; if (ch == " ") { u = min(1.0, u + gap_word_units * unit_len); continue; } string code = morse_of(ch); if (code == "") { u = min(1.0, u + gap_letter_units * unit_len); continue; } for (int k = 0; k < len(code); k++) { if (u >= 1.0 || total_pts >= max_pts_total) break; string sym = code[k]; float dur = (sym == ".") ? dot_units : dash_units; float den = (sym == ".") ? dot_mult : dash_mult; int sid = (sym == ".") ? 0 : 1; float u1 = min(1.0, u + dur * unit_len); // cap per-interval emission so one curve can't explode points int cap_here = max(1, (max_pts_total - total_pts)); int made = emit_interval(0, pr, u, u1, den, sseed + total_pts * 31, unit_len, spacing_units, jitter_radius, jitter_along, cap_here, pr, sid); total_pts += made; u = u1; if (k < len(code) - 1) u = min(1.0, u + gap_symbol_units * unit_len); } if (c < len(msg) - 1 && msg[c+1] != " ") u = min(1.0, u + gap_letter_units * unit_len); } } Edited January 30 by Librarian 1 Quote Link to comment Share on other sites More sharing options...
Theophylact Posted January 31 Author Share Posted January 31 @Librarian hey Thanks! Can you walk me through this, what’s the main steps, and do I also need Python? Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted January 31 Share Posted January 31 You can also use the clip node (clip attribute). The attribute can be generated by some random function (combined sin, cos, ...). You can clip your curve into two complement sets. One of these parts can be resampled for the dots and the other for the lines (ribbons). Here is a file with some ideas. clip_carve_lines_dots.hipnc 3 Quote Link to comment Share on other sites More sharing options...
Theophylact Posted January 31 Author Share Posted January 31 Yes I think, maybe I just need some density controlling algorithms or short way to just control density. Maybe I am overcomplicating things. Thank guy for info. Going to check this out Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted January 31 Share Posted January 31 Here is an approach combining resample nodes with sweep, noise and polycut. The VEXpression offsets the noise for each line. morse.hip 3 Quote Link to comment Share on other sites More sharing options...
Theophylact Posted January 31 Author Share Posted January 31 Guys! a huge bow down to you, I need time to digest your ideas Quote Link to comment Share on other sites More sharing options...
