Bernard Posted March 16, 2008 Share Posted March 16, 2008 Hello, I have some colored point with instanced geometry. I can't get the point expression to work .... Also the proxy geometry (instancepath) doesn't work. I replace it with a simple box. maybe someone can correct this file.... Originally it was a H8 hip file. thanks, bern instance_color_h9.hipnc Quote Link to comment Share on other sites More sharing options...
Marc Posted March 18, 2008 Share Posted March 18, 2008 Hey Bernard Did this work in 8? I'm trying to find the point expression you're having problems with and I can't see it.... Mind pointing me in the right direction? Thanks M Quote Link to comment Share on other sites More sharing options...
Bernard Posted March 19, 2008 Author Share Posted March 19, 2008 (edited) Hey BernardDid this work in 8? I'm trying to find the point expression you're having problems with and I can't see it.... Mind pointing me in the right direction? Thanks M Hello, I want to use the point expression in the color field of the material sop like this: point("/obj/instance1/create_variation",$PT,"Cd",0), point("/obj/instance1/create_variation",$PT,"Cd",1) , point("/obj/instance1/create_variation",$PT,"Cd",2) uploaded wrong file....sorry...this is the correct file. It doesn't seem to work thanks, bern instance_color_h9.hipnc Edited March 19, 2008 by Bernard Quote Link to comment Share on other sites More sharing options...
Bernard Posted March 19, 2008 Author Share Posted March 19, 2008 Hello, this is the Houdini 8 file of the same scene. Here they use an AttributeCreate to pass the point colors to the instanced geometry. The H8 Mantra ROP renders perfect the scene. If you create a second H9 Mantra ROP, this won't render the colors.... thanks, bern instance_color.hipnc Quote Link to comment Share on other sites More sharing options...
edward Posted March 20, 2008 Share Posted March 20, 2008 For H9, is this what you're trying to do? http://forums.odforce.net/index.php?s=&...ost&p=44883 Quote Link to comment Share on other sites More sharing options...
Bernard Posted March 20, 2008 Author Share Posted March 20, 2008 For H9, is this what you're trying to do? http://forums.odforce.net/index.php?s=&...ost&p=44883 Hello, yes , I want point instancing (not specific Mantra Delayed Load method), but the instanced geometry must inherit the color of my point. Thus, not just using a random function on the points (rand($PT)). If the Cd of the point is , let's say 'red', I want the instanced geometry on that point also to be 'red'... In the above example they use the rand($PT) function to generate a 'random' color. I'm after a 'specific' color, namely the color of my underlying points. thanks, bern Quote Link to comment Share on other sites More sharing options...
stevenong Posted March 20, 2008 Share Posted March 20, 2008 Hey Bernard, I think what edward means is he posted a hip file which should do what you want. Did you read through the thread or check out the hip file he posted? Cheers! steven Quote Link to comment Share on other sites More sharing options...
Bernard Posted March 20, 2008 Author Share Posted March 20, 2008 Hey Bernard,I think what edward means is he posted a hip file which should do what you want. Did you read through the thread or check out the hip file he posted? Cheers! steven Hello, yes stevenong, I did load the hip file and looked through the threat. In the hip they use the rand function on the $PT to generate the instanced color... In my example I want to use the point color (of my point geometry) to generate the instanced color. thanks, bern Quote Link to comment Share on other sites More sharing options...
stevenong Posted March 20, 2008 Share Posted March 20, 2008 Hey Bernard, Okay, I downloaded your file & the one toggle that makes everything works is the "Overrides use local variables" parameter in the material1 SOP. I turned it on & it works now. Also, I loaded edward's file & the setup is the same & he had the Overrides use local variables toggle turned on. Did you notice that? In the future, you can copy someone's SOP into your file & test with it instead. If it works, check what is the difference. In this case, it's a small but very important toggle. Last but not least, I opened the spreadsheet to check the values when changing the toggle and that helped too. Cheers! steven Quote Link to comment Share on other sites More sharing options...
Bernard Posted March 20, 2008 Author Share Posted March 20, 2008 Hey Bernard,Okay, I downloaded your file & the one toggle that makes everything works is the "Overrides use local variables" parameter in the material1 SOP. I turned it on & it works now. Also, I loaded edward's file & the setup is the same & he had the Overrides use local variables toggle turned on. Did you notice that? In the future, you can copy someone's SOP into your file & test with it instead. If it works, check what is the difference. In this case, it's a small but very important toggle. Last but not least, I opened the spreadsheet to check the values when changing the toggle and that helped too. Cheers! steven Thanks stevenong, edward. I think spending to much time behind my pc was not such a good idea. I overlooked this 'crucial' switch. My fault! Thanks again for the great help and pushing me in the right direction.... bern Quote Link to comment Share on other sites More sharing options...
