HOT1.0 for Ubuntu 64
Nico D.
Thanks, I ran ./compile.sh and everything linked up fine and I received no errors this time. Everything works in Houdini as well.
I have one question though. It's not really related to HOT, but I'm getting an undefined symbol output with anything I compile using hcustom. _ZTV9GU_Node17getVariableStringEiR9UT_String. Even the example SOP_Star.so causes this to appear, although it doesn't appear to be causing any harm.
Thanks for all the hard work. I'll try and post some images if I can get anything decent looking.
Thats good to hear. I also see the problem you mention, hopefully it will get fixed in the next stable release. Out of interest which platform are you using ?
-Drew
Edited by eloop
  • 5 months later...
I've updated the wiki to reflect the new src, just to save anyone else going through all the steps before finding this thread :).
If I get the 9.5.241 linux build working then I'll put it up there (Centos5.2)
Cheers
Marc
  • 3 weeks later...
Hi Varomix,
It looks like a problem with your compiler / system setup, fstream etc are all standard c++ include files and should be present. Can you try and compile SOP_Star.C from the toolkit examples using hcustom and check that it's working ok ?
-Drew
Hi
I'm trying to compile this fro ubuntu 64 and I get a bunch of errors
this is a part of the errors
the rest is in the text file
/opt/H9.5/toolkit/include/SYS/fpreal16.h:236: error: expected constructor, destructor, or type conversion before
