wreath Posted April 14, 2008 Share Posted April 14, 2008 Is that possible to use an animated object like moving in x axis box as a dynamic static object? i want a reaction between the animated box and other dynamic objects in the scene. Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted April 14, 2008 Share Posted April 14, 2008 Yes, use a static object, and in the OBJ Path parameter, put in the object that has the animation. HTHs! Quote Link to comment Share on other sites More sharing options...
wreath Posted April 14, 2008 Author Share Posted April 14, 2008 Gallenwolf thanks i tried it but not worked here is the scene, what is the wrong thing? dyn.hipnc Quote Link to comment Share on other sites More sharing options...
SpencerL Posted April 14, 2008 Share Posted April 14, 2008 Also make sure on the RBD Solver you have "Use Point Velocity For Collisions" turned on. Quote Link to comment Share on other sites More sharing options...
wreath Posted April 14, 2008 Author Share Posted April 14, 2008 Also make sure on the RBD Solver you have "Use Point Velocity For Collisions" turned on. Thats it thanks !! Quote Link to comment Share on other sites More sharing options...
wreath Posted April 15, 2008 Author Share Posted April 15, 2008 A new question; Is that any way to arrange animated static objects mass? there is no parameters for mass in static objects, i guess its calculating from objects scale + point velocity but i need to give some specific values so is that possible? Quote Link to comment Share on other sites More sharing options...
stevenong Posted April 15, 2008 Share Posted April 15, 2008 Yes, you can use a RBD State DOP. Check under the Physical tab. Cheers! steven Quote Link to comment Share on other sites More sharing options...
wreath Posted April 16, 2008 Author Share Posted April 16, 2008 Thanks Steven i saw physical param. node but state is what i'm exactly looking for, great! Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted April 16, 2008 Share Posted April 16, 2008 wreath, one thing to note from your file, is that I noticed your OBJ Path is pointing to the transform SOP? I don't think it works this way. It needs to point something on the /OBJ level. For example, animate a null, and then point the static object sop's OBJ Path at the null. If your geometry is not deforming, you do not want to check the "Deforming Geometry" toggle. It causes the SDF to be regenerated every frame. Which, if it's not deforming, will cause a lot of issues later on. Quote Link to comment Share on other sites More sharing options...
wreath Posted April 16, 2008 Author Share Posted April 16, 2008 Thanks Steven i saw physical param. node but state is what i'm exactly looking for, great! Thanks Alvin i will keep that in mind btw i really liked your robo-anim saw it a while ago. Quote Link to comment Share on other sites More sharing options...
GallenWolf Posted April 18, 2008 Share Posted April 18, 2008 Thanks wreath!!! Quote Link to comment Share on other sites More sharing options...
