Viewing shadows and textures in the viewport
If you put down a default grid and then apply the UVQuickShade tool from the shelf, does it work? You're not using a really old H9 build, right? Also, check the viewer display options and ensure that you have textures turned on.
I notice that is I use a shader that has an image file in it. it shows perfectly. So i can see the butterfly. But if I'm using one of the materials shipped with Houdini, it doesn't work any more. It might be a build problem, my version is about a month old. I'll upgrade and see what happens. Thanks!
