Jordan Posted May 6, 2008 Share Posted May 6, 2008 Hi guys, here is a noob's question. What is the extension of irradiance cache file? *. bla.bla.blah? Quote Link to comment Share on other sites More sharing options...
symek Posted May 6, 2008 Share Posted May 6, 2008 Hi guys, here is a noob's question.What is the extension of irradiance cache file? *. bla.bla.blah? *.cache? Quote Link to comment Share on other sites More sharing options...
Jordan Posted May 6, 2008 Author Share Posted May 6, 2008 *.cache? hi, symek. while i was waiting for your help, i fired off a mantra render with read/write mode set to write, and irradiance cache file without extension. Just came back from work now and notice the file without extension has a size of 112mb. And now i set the read/write mode to read, i notice the render is speeding up significantly which mean the file without extension is work. Original rendertime was approx 2hrs, now only 15mins. I have a new question now. if i would like to cache an image sequence, should i set it to filename$F4? or i just need to cache 1 file only for moving camera static scene? What about moving camera moving object scene? your help is much appreciated. jordan. Quote Link to comment Share on other sites More sharing options...
rob Posted May 27, 2008 Share Posted May 27, 2008 I have had a good look at this and the $HIP/images/myimges.$F4.pmap works fine. Rob Quote Link to comment Share on other sites More sharing options...
Jordan Posted May 28, 2008 Author Share Posted May 28, 2008 (edited) I have had a good look at this and the $HIP/images/myimges.$F4.pmap works fine.Rob Hi, rob. Thanks for the reply. A hip file will be much appreciated. please. Edited May 28, 2008 by Jordan Quote Link to comment Share on other sites More sharing options...
rob Posted June 3, 2008 Share Posted June 3, 2008 Hi, rob. Thanks for the reply. A hip file will be much appreciated. please. Scene file here http://forums.odforce.net/index.php?showto...t=0&start=0 Quote Link to comment Share on other sites More sharing options...
zasid Posted June 3, 2008 Share Posted June 3, 2008 Hello Rob, I have question regarding your file.How should I use the PMAP file if I rendering through IFDS? Thanks . Quote Link to comment Share on other sites More sharing options...
rob Posted June 4, 2008 Share Posted June 4, 2008 Hi zasid , You would render out your Occlusion and use it as a pass and then multiply it with your Diffuse / Colour pass in Cops or any other compositor. That way you get full control. At render time just read in the files , remember they are only good if you don't make changes ... Rob Quote Link to comment Share on other sites More sharing options...
pbowmar Posted June 6, 2008 Share Posted June 6, 2008 The Irrad cache(s) don't need any particular suffix. They're not really photon maps though so using "pmap" might not be appropriate. I use .cache but that's kind of generic and lame too. I'm going to stick with .cache just because I can't really think of anything better and it doesn't matter anyway Cheers, Peter B Quote Link to comment Share on other sites More sharing options...
Jason Posted June 6, 2008 Share Posted June 6, 2008 You can give them the .pc extension (Point Cloud) and then they'll be readable by the File SOP -- if you are ever curious as to the structure and data of the cache samples. Quote Link to comment Share on other sites More sharing options...
rob Posted June 6, 2008 Share Posted June 6, 2008 So Jason , can I write out a cache file for the 2nd type of occlusion myself and Mario have been exploring ? Quote Link to comment Share on other sites More sharing options...
