how do I get a normal pass in houdini 9.1?
Hi all,
I just found out how to get a normal pass in 9.1..
Here you go.
in mantra
/properties
/output
/extra image planes
make 0 to 1, and
VEX Variable : "N"
VEX TYPE : Vector Type
Channel Name : "Normal" (It can be anything, its just a name of the channel I guess)
When you bring the images to comp, choose channel "C" to "Normal",
You will see it,.
If there is something that I wrote wrong please alarm me!
For VEX Type, what should be best setting? Float or vector4 or vector?
Thanks~
There are some built in materials for this now too which might be worth checking out.
Hi, sibarrick! Where is ther material or what is the name of it? I would love to check it out!
and Is there any way to fake the normal pass and render x as red, y as green, and z as blue?
Somethin like that..?
Thanks!!!
Thanks!!!
Hi Jae Yoo,
1. In shops create a "Vop Vex Surface Shop" dive into it.
cheers
  • 3 weeks later...
well what if I want to render that out in different spaces like world space normals or tangent space normals etc...
thanks,
Ken
Not a problem; you can do it. You'll just have to transform N in your shader to the space you desire (see Transform VOP) and export that variable.
  • 4 weeks later...
surely this is more complicated for tangent space though no?
ie do any of the existing inbuilt 'spaces' equate to tangent space? I didn't think so...
